Novice needs advise on scanner(s) for Providence, RI
Engineerguy
Cranston, RI
Hello,
I'm looking to purchase a RS Pro106 Digital Scanner to monitor the Providence & Cranston Police and Fire Departments. According to my research this is the scanner that I need, however, because I am a novice I am seeking the advise of veteran users.
Thank you,
mciupa
Canadian DB Admin
Moderator
Hello Engineerguy, welcome to RadioReference. :)
Definitely the scanner that you will need for RISCON.
Consider also purchasing a programming cable and checking out WIN96 programming on trial .
Macomb, Michigan
I have Pro 106 and works good for me. Definitely get the cable and software much easier to program. I myself program mine by hand but that's for me. It can be very tidious.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Win96 does not work with the Pro-106. You can check out ARC500, Win500 or PSRedit500- all 3 have trial periods that you can use to check out the software. They're all linked from here... (all links are blue)
Object Oriented Scanner Software - The RadioReference Wiki
Also you will need a USB to serial cable to connect to the PC. This article lists the known models that are compatible and specific tips on how to load the drivers...
http://wiki.radioreference.com/index.php/Connecting_scanners_via_USB
73 Mike
