OkieBoyKJ5JFG
- Joined
- May 16, 2022
- Messages
- 238
- Reaction score
- 209
I recently installed some NMO mounting points on my truck, but for a variety of reasons, I wasn't entirely satisfied with them and decided to do it over. For the first installation, I used generic Chinese RG8X coax, but this time I went with USA-made MPD digital RG8X. The first thing I noticed was that the MPD coax is much more flexible and easier to work with, but even more significant is what happened to my SWRs/Smith graphs. With the Chinese coax feeding a Diamond SG7900 Super Gainer NGP 2m/70cm dual-band antenna, the 2 meter and 70 centimeter bands were good, GMRS was in the "I can tolerate it if I don't use it too often" range and MURS (Which I've never used and could live without, but why not test it?) Started at 2.0:1 and went up from there. The first four pics are the sweeps of GMRS, 2m, 70cm, and MURS in that order with the Chinese coax and the last four are the same after changing to the MPD coax on the same antenna. 2m and 70cm remained good and even improved a little, but GMRS and MURS improved dramatically -- all the way to, "Yeah, that'll do." If (like me) you have sometimes wondered, "Does it really make that much difference?" the answer is yes, it does. The MPD ain't cheap at $2.34/foot, but I only needed 30 feet. TBH, even if I needed 100 ft, I'd buy the MPD. The difference is that obvious. As the saying goes, if you buy the best, you only cry once.
