Thanks, those (to me) are the most fun to explore.
That's showing an interesting thing, but I'm not sure if it's common to all TDMA systems, all Motorola systems, or something else entirely. There is a "TDMA Sync Broadcast" being sent out - TDMA operation relies on particularly precise timekeeping - and it's stated to be invalid. It could be that they haven't configured a network time protocol, or just that it is considered invalid by default unless specifically set up.
For the sake of reference, your PC's clock appears to be 2 minutes fast compared to them:
Code:
30 00 00 04 6A 1C 8F 06 A0 96 80 BE 04/14 21:55:14 TDMA Sync Broadcast - *Invalid* 2014/04/15 00:53 (150) -10
I don't recall what precisely the number in parentheses means. It appears to slice each minute into ~8000 pieces. It's in the standard (which is interesting reading if you are into this kind of thing, but costs $$$ to even have a chance to look at it).
There are indications of Motorola-specific opcodes (instructions sent over the control channel), but it is not an "X2" system. I don't know if that means you are restricted to seeing only Mot radios on the system - presumably a non-Mot radio coming across an opcode with manufacturer code 90 (Motorola) would just ignore it, but I haven't seen a system set up that way yet.
The Motorola opcodes are as-yet undeciphered, but if I recall correctly, some of them have been suspected to be related to what talkgroups are patched together.
One last thing, since this system is theoretically going to replace a Smartzone system: Motorola makes a bridge device called SmartX which is used to link SZ systems with P25 systems (maybe with other systems too, I don't know). When a SmartX bridge is used, and talkgroups on the SZ system are carried over it to the P25 system, those talkgroups are almost always showing up as their "5 digit" values divided by 16. That is to say, the number you are putting into your scanner for the Smartzone talkgroup, divide it by 16, and put that into the P25 system, and that should be the same talkgroup. So for example, your HRP Central Primary channel, 58112, should be 3632 on the P25 system,
if they link them with a SmartX bridge.
