Numerous decoding errors on 2p39 no problems on 1.101 public
Jtolar
Chief Dog Petter - Radio Junkie
Birmingham, AL
I just got the latest fastlane version and it has a really hard time decoding a p25 system that the 1.101pt public version get very few errors. A lot of the errors are UNHANDLED EXPLICIT OPCODE: #4. with the previous public version I rarely get decoding errors. I have switched back 1.101pt as my feed was horrible to listen to. I am new to the software as I have only been using it for about a month. I am not sure if this is something I need to optimize or is it a problem with the raw data. I recorded a big chunk of the raw feed using the R key so if that will help let me know where to send it.
Code:
[E] Channel Group & User: Tgt=2563 Src=45301
Sync:-P25p1 NAC:3C0 LDU2
Sync:-P25p1 NAC:3C0 LDU1
UNHANDLED EXPLICIT OPCODE: #4  900FFFFFFFFFA030  TG=2563
Sync:-P25p1 NAC:3C0 LDU2    e:rDrDrDrDrDrDr
Sync:-P25p1 NAC:3C0 TDU
Sync:-P25p1 NAC:3C0 TDULC  UNHANDLED EXPLICIT OPCODE: #4  900FFFFFFFFFA030  TG=2563
Sync:-P25p1 NAC:3C0 TDULC  UNHANDLED EXPLICIT OPCODE: #4  9071FFFFFFFFFFFF
Sync:-P25p1 NAC:3C0 HDU
Sync:-P25p1 NAC:3C0 LDU2    e:DrCrCrCrCr
Sync:-P25p1 NAC:3C0 TDULC  ERR3   UNHANDLED EXPLICIT OPCODE: #4  900FFFFFFFFFA030  TG=2563
Sync:-P25p1 NAC:3C0 TDULC  ERR41
Sync: no sync
slicerwizard
Toronto, Ontario
I don't see any decoding errors. If you don't want to see those (non-error) messages, lower the verbosity level. I'm guessing they're some Motorola proprietary message that DSD+ doesn't understand. If the synthesized audio sounds bad, upload a raw audio recording somewhere. Someone should be able to figure out what's wrong.
Jtolar
Birmingham, AL
Okay so this was a issue with logging level. I wasn't used to seeing that level of logging and took it for errors. I do seem to get more decoding errors than I used to but not sure if that is due to the newer version or something going on with the feed. I have the latest running on one of my feeds now (feed 25237). You can hear a good bit of errors. Is there a optimization guideline or something? Although I am new to the hobby I am a very technical person. I have been a programmer for 20+ years so I am not afraid to empty the bit bucket and refill the token jar.
Jtolar
Birmingham, AL
I have a rtl-sdr.com dongle for each feed. I have the raw audio but where should I upload it?
Ghstwolf62
Clifton Forge Virginia
Also try running DSD Tune I believe it was called. Its a great program the people who do DSDPlus put out that tells you the best settings to use for a particular system. Not sure where you can find it but its around somewhere I'm sure.
