NX-300 NEED HELP
BG8KSU
hi,everyone, I am a beginner here.I got a NX300-E,U400-470. it can be read&write,tx&rx,but its wrong with TMIER,the Clock counts very fast,and after a little while the nx300 crashed. I I tried to flash firmware,reset,but the problem still remain. If I turn the clock off,everything goes ok. Does anyone know what's going on?THX
There's a RTC (Real Time Clock) in these that may need to be adjusted. That's done via the test mode.
Unless you have the right tools to make adjustments in the Test Mode part of the software, I'd strongly suggest NOT making any changes. If the radio works fine with the clock turned off, then leave the clock turned off. I never ran ours with the clock active.
BG8KSU
Thanks,I tried to adjust RTC,in RSS test mode,just one click,it can be auto adjust.But this way didnot correct the clock,maybe it's a hardware problem.
