NX-300 Programming
berg6728
Is there away to have the backlight turn on when using the channel selector knob?
Using KPG-111:
Step 1: Read the radio.
Step 2: Save the file.
Step 3: Save the file again somewhere else.
Step 4: If you ignored step 2 and 3, go back and do those.
Under "Optional Features 1:
Common Page 1 tab:
Click the "Auto Backlight" box.
If that's greyed out, it's because you have a button programmed for the backlight function. Remove that function from the button, then go back and it'll be "un"-greyed out. Click that box.
You can set the backlight timer on the same page.
Write the file to the radio.
Save the new file.
Save it again somewhere else.
berg6728
Thanks! Can I still program a button to turn the backlight on also or not?
berg6728
Ok thanks! Thought so! I followed your instructions got it to work, even if still push the button I had it programmed to backlight still comes even thought it’s not programmed to any buttons
Right, any button push will activate it, so really no reason for a dedicated button.
