NX-420-K2 Volume Stuck At Max
BigRedBox80
I have a NX-420-K2 that, once turned on, the volume seems to be stuck at max. This was a sudden change and programming does not indicate this should be the case. Does anyone have tips on whether this would be a control issue or main board issue?
bjred
If the programming is good then it's probably a bad volume pot and/or damaged flex cable from the volume pot going to the TX-RX board.
Yeah, there's minimum volume settings in the software, that if cranked up will make it do this. But if no one made any programming changes, it would indicate an issue with the volume pot.
I haven't got a lot of 420's, but do run some at work, and never seen one fail that way.
