NX-5000 / NX-3000 Software and Firmware update - 12-01-17
kd4efm
EL98 Florida
JVCKENWOOD announces the release of the NEXEDGE NX-3000 Series Firmware Version 1.20 and related Software KPG-D3N R1.20.
This firmware release includes the new DMR feature, DMR Auto Slot Select and KPG-D3N Personality Table improvement.
JVCKENWOOD announces the release of the NEXEDGE® NX-5000 Series Firmware Version 2.40 and
related Software KPG-D1NK R2.40.
This firmware release includes the new DMR feature, DMR Auto Slot Select.
Contact your local dealer / sales rep. for more information please.
kd4efm
EL98 Florida
Please oh please tell me import got fixed. Guess I'll have to update and see......
Sent from my SAMSUNG-SGH-I337 using Tapatalk
LOL, takes forever for the server to respond, but I am downloading the files now Dave.
kd4efm
EL98 Florida
The “DMR Auto Slot Select” function in the NX-5000 V2.4 and NX-3000 V1.2 allows the subscriber
unit (SU) to automatically switch when used with a DMR repeater. This functionality allows for
efficient slot usage without the user to having to change channels to use a different slot on said
repeater. The same Color Code (CC) must be applied to both Slot #1 and Slot #2.
NOTE: DMR Auto Slot Select functions in repeater mode only. DMR Auto Slot Select cannot be
programed on a channel configured for Direct mode operation. In the case of the use of the talk
around function the channel with the Auto Slot Select programming, the SU is fixed on Slot #1.
SAFFA
World
I wonder if this "auto slot select" will be available in the lower tier TK-D240 in the future?
I presume it's the same as hytera pseudo trunk.
KK6ZTE
California
How will this work on poorly configured systems that use two timeslots as individual groups but with the same talkgroup id? I doubt it will handle it well.
I've ran into a ton of those systems--it's extremely infuriating.
kd4efm
EL98 Florida
I hear you, but that would be a radio shop key to getting a new service customer and make it correct. Just saying. But you can do it the same way now on a Kenwood, if that's what it took.
Sent from my SM-G935P using Tapatalk
kd4efm
EL98 Florida
I do not see it updated on 166 or 170. So for now, no, but don't hold me to it. Just has not been released.
Colton25
After updating to 2.40 on my 5700 I have noticed the clock no longer keeps time. I can write to the radio and it corrects the time but as soon as the radio cycles power the time is either blank or incorrect.
kd4efm
EL98 Florida
Can you video it doing that?
I'm working on another bug report.
Colton25
Yes can I email it to you? Also not sure if you read my other post in a different thread about the MDC ID’s being cleared from the screen as soon as a new signal is received regardless of how long I set the timer for. This seems to be a bug that has been common in all firmware releases.
kd4efm
EL98 Florida
Not really a bug if you are in scan. I asked about it. They suggested having call ID stack turned on if you need to go look at who it was.
Colton25
Ok disregard then, just new to me. My X180 radios would always display the ID with scan being on or off.
