NX-5000 Series Out of Band
AF1UD
I came across some information that states that you can program a NX-5300 and take it slightly out of band. Upper Band - Down to 440. Lower band - Up to ???
Does anyone have any information as to how far I can actually go? The KPG-D1N software says it's out of band, but allows me to program it anyway...
Are they built off better chips than the NX-3K Series? Because those will do 400-520mhz in 1 radio.
Thanks!
AF1UD
Will it receive past that? Or is that just for TX?
AM909
Radio/computer geek
SoCal
? The spec for the low-split K5/K6 is 380-470 MHz (i.e., including all of ham). As far as the 3K series having "better chips", wider tuning range is usually not better.
AF1UD
I was looking to see if it was possible to stretch a low-split to ~500mhz and/or a high split down to 440mhz.
n3obl
Ø
PA
a low split will not go up to 500. maybe 476 tops..
high split should handle down to 440.xxxx
