To anyone looking to acquire commercial radio programming software:
How difficult would it be for Kenwood to allow more 2-tone decode sets within a single transceiver, or even allow 4 sets per system? Seems crazy to me that these radios can hold up to 4,000 channels but they can only hold 4 2-tone decode sets.
New genuine USB cable is really fast. Looks like it works not on 115kbps speed or something, looks like it runs on 512..1024kbps. And it does matter even you have just one radio. Here is what I see with my NX5K: 5 minutes vs 30 seconds.
And YES, I also noticed that 1.71 SW allows to insert zone at the end OR wherever you want. So, we see some very slow progress with programming software. I am pretty sure that it's absolutely possible to implement zone move, zone merge, zone copy/paste, programming data import/export, etc., and we will see these features sometimes.
Hi Evans
Thank you for your email
I have verified the zone add check box;
If you un-check a zone add box and make new zones the check mark in the zone add should be blank it should not be checked when you add more zones.
I will be in touch I need to write it up and submit it.
I just acquired an NX5800 so i am looking at doing a dual-deck setup (NX5700/5800).
Is the multi-deck RX firmware option required or will this configuration still operate with multiple decks without simultaneous RX?
Long term goal is to add the additional FW features as budget allows.
Found the answer to my own question finally, if anyone is looking for a radio case to be used with a radio strap i found this site that makes them, only place I've found so far. The case isn't on their website yet because they haven't updated but they do make a case for both full and limited keypad. Welcome to RadioTech | FDNY Straps | Leather Two Way Radio Cases
For the portables auto backlight feature is available, in the software it lists backlight when PTT press, key operation, and ID/Message operation. Regarding ID/Message operation does this mean when receiving something like a 2-tone, or will the backlight come on with RX audio?
You know I thought the same thing, but it turns on for everything except getting a regular voice message. The moto xpr 5550 lights up for just a general voice message. I wish they would add that so it would light up while receiving a normal message...
With the lever switch on the portable being 2 positions the software allows you to program a function for each position. How does it work if the function programmed is a on/off function such as scan? For example normally if a key is programmed for scan, you would press the key to start the scan, and to stop scanning you would press the same key again. With the function switch if I set position A to scan, I would assume you'd have to program position B without a function this way when you switch to position B scanning stops, am I understanding this correctly? With the scan scenario wouldn't the "2 function switch" become a single function switch?
I saw a couple older threads involving questions about scanning issues where the mobile radio would freeze up on a P25 channel. My mobile radio will be scanning and I'll notice it goes silent and there will be a unit id number froze on the screen and the radio doest resume scanning. Was there a answer found for this problem???
Is there anything special that is needed inside the computer besides Bluetooth capability? I have a Mac running parallels with Windows 10 and I'd like to use the Bluetooth programming feature will this work?
