NX-5200 Bluetooth programming
Arizona
I am having issues with the Bluetooth programming. Radio has the KWD-5003BT key installed. Everything seems checked that can be for the bluetooth. I have changed the comport for programming to Bluetooth. Bluetooth is turned on and I can pair the radio and computer but get access denied. Attempting to read or write I get the connection beeps and then the radio disconnects within 3-5 seconds. Both radio and D1N are at 4.20. Any advise?
kd4efm
Florida
You don't pair the radio to the PC to program it, you set D1 to BTSPP as the programming cable, and let the software find the radio via BT.
Let the software do the work.
Arizona
It ended up being the comport for Bluetooth not set correctly in the serial interface under optional features 1. Thanks though.
KG4BKO
Vidalia, GA
I am having a similar problem. Could you tell me exactly how you set up the comport for Bluetooth under optional features 1?
kd4efm
Florida
D1, you change the com port to BTSPP, to read, you let the pc find the radio, you dont pair the radio to the PC.
80011
KG4BKO
Vidalia, GA
Hi Evans. I get that. What settings to use for Optional Features 1 - Serial Interface - Com port Bluetooth? When I try to read NX5700 via Bluetooth It connects and then quickly disconnects with an error. Thanks in advance.
KG4BKO
Vidalia, GA
I have that checked. I must be missing something simple. This is my first radio using this software. It is a big learning curve. Hope to see you at Orlando. Thanks a bunch.
kd4efm
Florida
i will be there saturday for sure! I will bring my laptop to double check it for you. Allegedly I will be at a table somewhere in the swap building
KG4BKO
Vidalia, GA
Thanks for the offer. Mine is an NX5700 mobile so it will be in the truck. I may bring my laptop to you to see if I have everything set right. Either way I have some other questions I would like to ask you when I see you. Thanks again.
Bill1957
New Jersey
Anyone figure out the connect and quick disconnect with the bluetooth programming?
kd4efm
Florida
right now, he is checking to see what firmware he has in it. Met with him at the hamfest in Orlando
KG4BKO
Vidalia, GA
Hey Evans. I sent you an email with my radio configuration. I have firmware 4.00.00 and cps v 4.20.
KG4BKO
Vidalia, GA
Yep. Finally got it going. A local friend helped me get it set up. Apparently I did not have Bluetooth (Rf Deck/Control Head 1) clicked under Optional Features 2 clicked. Don't know how I missed that. So many options in the software, ha ha. Thanks for all the help. I am loving this radio.
