NX-5200 Key Noise
Remington12G
GØT AES?
I have had my NX-5200 for about 2 months now, I wrote an updated codeplug to my radio today and now when I press my key I have set up for backlight it emits a beep, I didn't have then on before and now I'm confused on how to turn it off in D1N. For reference, I have the emergency button set for a single push to activate the backlight.
Forts
Mentor
Ontario, Canada
Is it thru a menu option perhaps? On the MotoTRBO gear I don't believe there is an option to enable/disable just the key beep in CPS, however it can be done via the utility menu in the radio.
I know it's an option, usually under the 'audio' settings in the front panel menu. I don't have KPG-D1N here, so I can't check.
Remington12G
GØT AES?
Issue resolved. The AUX Key was no longer set to backlight somehow but now is. Beep is gone
