NX-5200 questions before buying
nucleaireqc
I saw a radio for sale on a radio group but this one forgot the write password of the radio.. is there a way to erase the password and programming?
I saw that there is a usb port on the is it the port to program the radio?
thank you because kenwood radios are not my knowledge.
There is a bit more to this you need to figure out.
There are 3 password levels on the radios:
Read password - if active the radio can only be read with the password.
Write password - if active the radio can only be written with the password.
Read/Write password - both of the above.
If it -just- has the read password only, you can create a new file and overwrite the radio with a new codeplug without a password.
The other two, you either need the password from the original owner, or you'd need to send the radio in to Kenwood to have it wiped.
I'd be cautious about buying a radio like this. There's a lot of questionable sellers out there who sell radios with questionable backgrounds. A big agency won't "forget" the pass word. A small agency may have their radios programmed by a local shop, who may have put passwords on the radios to lock them into the specific shop.
Getting the password removed may turn out to be costly. If the deal seems too good to be true, it probably is.
n3obl
Ø
PA
on a NX-5200 there is no USB port. You need the appropiate programming cable. Now the VM series mobiles can have a remote front on the deck with a USB port available.
charger battery have a usb port
?charger battery?
Some aftermarket batteries have an external USB port for charging, but it's not for programming the radio.
?battery charger?
The KAS-12 battery reader has a USB port, but that is only for reading the battery data, not for programming the radio.
The KPG-36 is the USB programming cable. It is for programming the radio and will not bypass the passwords.
