NX-5300-K2 Out of Band?
AD0JA
Repeater Collector
Will KPG-D1 accept ham 440MHz frequencies for the 450-512 split NX-5300?
If you have used D1 successfully with out of band operation on this radio, let me know.
Thank you.
I'm only using NX-5700's, so never needed to try.
However, I've heard from several that they were successful in making a 5300 work down in the 70cm band, as far down as 440MHz.
But, keep in mind if you want to use analog, the stock NX-5300 and KPG-DN1 will force you t use 12.5KHz narrow band FM. You would need to procure a W-license from Kenwood to open up the wide band FM.
AD0JA
Repeater Collector
Thank you for the information, that's exactly what I needed to know.
kd4efm
EL98 Florida
Radio will go 5 to 6 mhz up or down depending on the split.
I use a 5300k6 and a 5800k2, it works fine on our T Band UHF sites with our state-wide NXDN system
whenever I go into south florida, trunks with now problems.
