Nx 5700/5800 question
glff2
Westminster
I know it can be done but is there someone out there that knows how or could help me with something. There is a way for each radio speaker to be on a 2 separate volume knobs besides the master on the main control head. An 8 ohm knob and speaker wire plugged in to each speaker connector. Has anyone done this or could help me out with it? Any help is greatly appreciated. Thanks
kd4efm
Florida
not in remote configuration, the speaker out jacks are 4 ohm 4w output. The volume is controlled by the control head and main deck selected.
the unselected deck is set at -3, -6 or -9 db down, which can be set using that in the menu options.
glff2
Westminster
I've seen it done. It does work with 2 separate volume controls. They tap into the speaker connectors. Just plugs in each speaker. I'm just curious how to do it. The master volume for both is on the control head. The 2 other knobs would be put in a mount.
n7maq-1
Oregon
You just need two L-Pads. An L-pad will keep a constant load impedance on the output of the audio amplifier. Just come off the 3.5 MM jack to the L-Pad then to the speaker. As KD4EFM said, keep the output levels all same.
Jim
