NX-5700 Dual Remote head power issue.
BobDigital
I have a truck with the NX5700 dual heads. One was bad, so I put a new one on, same model. The firmware needed updating, so I was starting that process when the radio powered down. The truck was not running when it happened, so I don't know if the radio turned off because of that, or something else. Now, I can't power the remote head units at all, even if I swap back to the original. I have power on ignition sense and the +12v lines. Any help would be appreciated.
AF1UD
Try taking off the ignition sense. I only run my'n without it and when power is introduced they come on, and when I leave the car I just have to turn them off.
snoopyII
On the other side of the tracks
You first mistake was updating the firmware with the vehicle off. It's highly likely that you just bricked the whole radio. Anytime you are writing to the radio codeplug, or especially firmware and lose power to the radio mid-process, is a very, very bad thing. This could prove to be a costly lesson, I doubt there anything you can do at this point except to send it in for repair.
Arizona
Sounds like a trip to New York or California is in order repair centers is in order or your setup. I have had better luck sending to California as far a turnaround time. ALAWAYS make sure to update radios with a stable power source, or vehicle turned on. Firmware upgrades are literally telling the radio how to perform, so a loss of power during a write leaves the radio without the info it needs to operate. This is also true with your laptop, I almost always get my laptop plugged into power during a process like this.
BobDigital
I wasn't actually writing. To clarify, I had the software, KPG-D1SL downloaded, and I tried to write, but I would get an error about the com port. Additionally, after talking to another tech, he told me that I needed to download the firmware .zip file, and load that onto the software to write, so I hadn't done any of that. When I put the new head on, dip swith #4 was in the on position, but after looking at the old one, i moved the switch to off. I was attempting to write (incorrectly) when the unit powered down. I disconnected all plugs from both units this morning, and turned battery switch to off, plugged everything back in and powered truck on, no change.
ramal121
Lots and lots of watts
Calif Whine Country
So you are taking a single head radio (that was working) and adding another head to make it a dual. Is that correct?
ramal121
Calif Whine Country
Or you are replacing a single remote head that the original is perceived bad? You are not being very clear here.
BobDigital
Sorry, it is a dual head unit, with one head being bad. Oddly enough, I found a bad fuse, and replaced it, and the head works now. The weird part is I had voltage to the transceiver.
