BigLebowski
Does anyone here successfully have DMR Site Roaming on the NX-5x00 series working? Does it work similar to roaming on a Motorola DMR Portable?
If I understand the concept/help file on the NX-5000 correctly, I should be able to create a Personality for each talkgroup on the NC PRN system, each having all of the sites I want to be able to roam to:
Then create a Zone for the NC PRN system as a whole and put the first channel of each personality (for each talkgroup) in that zone, and when I am sitting on that channel, it should roam between all of the sites assigned to this channel.
Am I understanding this correctly? Anyone actually using this method?
Trying to get this radio programmed on the bench so I can't test if this actually works.
Thanks!
Thanks!
