NX-5800 extended recieve
rtc1930
Is it possible to receive slightly outside the bands on a NX-5800 (380-470mhz) at ~477mhz or is that blocked in the SW?
Not really looking to transmit, just "scan" but it is a DMR channel. Worst case I will add the 450-520 as my third deck but was trying to avoid for such an edge case.
Bob
kd4efm
Florida
Diminished RX, but yes. My K2 works between 470 and 475 in Miami, so listening should be okay.
It will say out of range in the software, but will still take.
rtc1930
Thanks! I thought i read that somewhere but wanted to be sure it wouldn't cause any issues.
kd4efm
Florida
There is a 4 Mhz window that I have found in the K2's, but since the Florida FleetTalk system in Miami uses 470 to 474 (3 MHz +)
I have not seen any issues when roaming in south Florida on T Band channels. Plus the area is pretty well covered down there for
radio use.
