sraider
Have power to radio and ignition sense wire. Worked fine one day then the next day won't turn on. Tried holding power button for 5 seconds nothing. Is there an issue with these radios or just bad luck. For what they cost new, can they be fixed?
This is actually the second one that stopped working. The first one that stopped working this spring hardly gets used, the one that went now gets used alot during harvest season but then sits mostly unpowered for 10 months.
Also does kenwood make a simpler nexedge radio? They are only used for our own company. Don't need a 1000 channels when I only use 3. Have our own repeater system so don't need trunking. And the programming is a hard learning curve when you rarely use the software. I do have some nx-3820, but they are also way more than I need.
