NX-5K DMR Roaming
tweiss3
Is it time for Coffee?
Ohio
Not to bring up an old subject, but after reading the DMR Function V2.20 manual, and the following threads, I have a few specific questions:
If I am understanding it correctly, operation is similar to other manufacturers, except it roams using the information in the channel-zone list, not from a roam list noted elsewhere.
1) There was mention of roaming and checking CC. Do all repeaters have to have identical CC? Is it a problem if they do not?
2) What is the best way to deal with properly assigning TG to slot? I'm assuming it's different than the typical 1 zone per repeater, and strap each TG to a channel. Do I put each repeater in twice, for S1 & S2, then the roaming only looks at the selected slot's channels? I'd be ok with this if I can put Group ID search on and go into the contacts to make my group call.
3) I am assuming the roaming doesn't also sort by strapped talkgroup? I can't put Repeater 1 TG 1-5 in channel 1-5 and Repeater 2 TG 1-5 in channel 6-10?
The other threads were helpful in tweaking the roaming settings. I just need to get a complete understanding before I blow forward. I currently have the large codeplug as zone-channel not personality list. I'm trying to get this squared away on the portable before I load it into the mobile where changes are a bit more effort.
kd4efm
Florida
1) it can be different CC's
2) in each zone (that's your TG on all repeaters) you set the single tg for site roaming
3) that would not make things easy. Stick with Zone = TG.
EFM
tweiss3
Ohio
That's what I needed to know. I'm not sure why I didn't think of that.
