schester
I'm clearly missing something as I'm sure this is a supported operation and I can't believe it would be a bug. I have only tested this on a NX-5300. I could test on NX-5800, but haven't yet.
In Personality mode. I have a personality that does not have Group ID Scan checked. I also have Dual Slot Direct Mode disabled on this personality (working with a Zumspot). I have a group ID list and persistent group IDs configured, but the persistent group IDs are a subset of the Group IDs available in the group ID list.
If I select one of the non-persistent group IDs and PTT (for example 310), it shows up on the display and connects the Zumspot to the talk group, but I never receive any audio. The radio shows that it is receiving signal and I can confirm via Zumspot dashboard that it is transmitting the selected talk group, but the squelch is never opened. With the same programming, if I select one of the persistent Groups it works as expected.
When I first tested this, without group ID scan I was receiving any audio, even for the IDs that were configured as persistent. Not sure that I changed anything, but I wrote the data again and it seems to be working as expected there now.
Surely there has to be a way to only hear a talk group on demand / dynamically. I expect that after the time out I would no longer hear the dynamic group, unless selected and PTT'd again to reactivate the group.
I suppose it would be worth testing this on a personality that has dual slot direct mode enabled.
