NX 700/800 and Zello
cbrrider06
To all. Is there a way to set up the nx 700/800 to work with the App Zello, via a desk top computer? If this has already been ask, share the link or page for me to review. Thanks in advance.
I am a lineman for the county.
The audio in/out/PTT pins are all available on the rear DB25 connector.
You'll need to program the radio correctly to use those pins.
But that should let you interface to whatever computer to radio interface box you are going to use.
How you do it depends entirely on what you are using for an interface box. It will not be a plug-n-play thing.
It will also depend on your skill level.
We have several NX-900's interfaced to a console, they are designed specifically to do this. It takes some work and all the settings will depend exactly on what you have.
cbrrider06
Basically I have had the ideal about linking my base radio which is programmed to my Local Ham repeater, to the Zello app running on my desktop computer and in return i can talk with the app on my phone and be able to talk to the repeater.
The radio will support that. You'll need the interface between the computer and the radio. Not sure what's out there for Zello.
The audio/PTT interfaces are on the DB25. You'll need to program the radio to accept those inputs. It's not difficult, but you will need to set that up before it will work.
Running LMR radios in an application like this is fine. Usually LMR gear is designed for 5-5-90 use, 5% listen, 5% transmit, 90% idle.
Hams (no offense, I'm a ham also) tend to be long winded and can quickly overheat a radio if they tie it up for too long. Maybe not a problem for you, but others using the link may not understand.
Run the transmitter at its lowest power setting. 5 watts into a good antenna should be more than enough to get into any local repeater.
Use a good antenna/feed line so you get a good signal into/out of the repeater.
Set a time out timer on the radio, 60 seconds should be more than enough.
Ideally, you want a way to kill the link remotely if it gets locked up or someone gets into it that shouldn't be. Not sure what Zello supports.
cmjonesinc
To add to the killing it remotely part... If you log in to the "feed" zello account on a different device it will log the original one out. That won't be super useful if there's a hardware problem betweem the radio and pc but it's an easy way to "remotely" kill the application. I don't think zello (the free version at least) supports any other way to remotely kill a feed.
jcefd10
WWG1WGA
Im probably late to this response. But I have set up Zello Work with a NX700 for our FD and several other agencies in the area. I ordered a gateway from ROXI and he sent the cables I needed along with what instructions to program. Once I got it tweaked it had worked perfectly. I can help you out if needed.
emacs
New York
I have also dealt with Roxi gateways for a few local agencies and they work well. If you don't want to shell out for a premade interface cable, they're pretty good about providing pinouts so you can make your own.
