NX-700/800 Repeater Cable
SNCZCA01DS0
Ok! I will that a try after while! I have about 2 feet between antennas right now but have more space to separate further.
Vertical separation (one antenna above the other) is more effective than horizontal separation (antennas beside each other. But, it can take quite a bit of separation to reduce desense enough to let the system work as well as it can.
A properly tuned mobile duplexer is a more effective approach.
WQVC723
Fairlawn, Virginia
I will see if I can find a mobile duplexer online then. I can get more vertical separation but may end up going with a duplexer. I really was more interested in a cross band repeater when I started this project that has turned into a how many radios can I get to do mobile repeating. But I will look around eBay and see what I can find for a mobile duplexer.
kayn1n32008
ØÆS, I put that shØt on everything.
Sector 001
You will get better results with the duplexer. It’s a pain in the rear to use two antennas, with out the right amount of verticals separation along with filtering.
Jordo2114
Any advice welcome.......So I got my mobile setup working with 2 NX series radios just as described above.....And it works great !! Except i am having one little hang up.... When I shutdown 1 radio the other keys up ......I think this is because the TOR and EXT PTT is looking for a low signal and when one radio powers down the other perceives this as a LOW input. I noticed I cannot change the settings in the radio to trigger on a High input as it is grayed out in the program. Anybody else experience this problem or know of a work around? Other than that it works great thanks !
WQVC723
Fairlawn, Virginia
I have that problem as well. I just power down both radios and when I power one back up it quits.
Jordo2114
Yeah I was hoping we could find a permanent solution I think I could do it with some relays .........
WQVC723
Fairlawn, Virginia
If you can please post it. I’d love to find a way. I’m going to add switches to mine to be able to turn the repeater feature on and off. So that may be my solution to the problem.
Jordo2114
Yep I was sort of thinking the same thing with a few relays I could program a key on front panel and use another AUX Out to make the repeater on and off capable......
