NX-700 DTMF Mic
kb9905
Hey,
I got a cheap KMC-32 mic for the NX-700. The mic with tx and audio is good. But no DTMF tones are sent. Is there a setting somewhere or is the mic broken? My stock TM-281 mic does the same thing on this radio. Any ideas?
I am a lineman for the county.
If you are using the NXDN side of the radio, there's also settings under "NXDN" on the "General 2" tab that lets you select the type of microphone. That's won't impact DTMF, but it's something to be aware of if you start using NXDN and want to mess with the audio. Set up properly with factory mics, these radios sound really good.
kb9905
Thanks very much. It's been a long time since using KPG-111 and haven't ever had to enable the DTMF. Makes sense now. Works now.
