NX-700 issue
Res21cue
Res21cue
Looking for some help here. Up until this morning my NX-700 worked perfectly fine.
Now this morning, its like its delayed. It usually powers up at the exact same time as the Uniden Scanner, and always has, but now suddenly it is 3-4 seconds behind the scanner, but when it powers on it is full bright as expected however the LCD Lettering is super super dim, almost non existent. Its almost as if its cold, except its not.
I checked all the power and ground wires, all is well. Even when I manually turn it on with the soft key it is 3-4 seconds delayed.
Rx and Tx work perfectly fine, no issues
Im at a loss.
kd4efm
EL98 Florida
Now this morning, its like its delayed. It usually powers up at the exact same time as the Uniden Scanner, and always has, but now suddenly it is 3-4 seconds behind the scanner, but when it powers on it is full bright as expected however the LCD Lettering is super super dim, almost non existent. Its almost as if its cold, expect it not.
Im at a loss.
How old is it?
Might be an ic going bad.
Sent from my SM-G935P using Tapatalk
Res21cue
Res21cue
I bought it used so I cant say for sure. Atleast 5 years old with no issues over any of those 5. Only thing I have left to try is to remove the head, reseat the ribbon but I dont have the tools with me to get the faceplate off the console right now.
Whats an IC?
kd4efm
EL98 Florida
Whats an IC?
Intergrated chip.
Check the ribbon for sure.
But chances are, a trip to depot for a fix.
