NX-700 Microphone plug angle
RRR
OFFLINE
USA
So, I have my NX-700 in my vehicle, but where the mic plug-in is, I need it to run straight up or down, as opposed to sticking straight out (I have had to zip tie it, and have it return back towards behind the radio head)
I was thinking of getting an offset Mic. connector, and was wondering if a standard RJ-45 adaptor would work.
(Ebay link - Screw Panel Mount Right Angle 8P8C RJ45 Female to Male Connector Network Cable | eBay )
Has anyone else tried something like this before?
Anyone foresee any issues?
Hiding in a coffee shop.
If it's straight through, then it should be just fine. I'm sure it is.
Other option is to build an adapter off the rear 25 pin connector and you can put your mic wherever you want. Your solution looks much easier.
RRR
OFFLINE
USA
I use a remote head, the radio is in the back.
The way the head is mounted, it is pretty inconvenient for the mic cord to stick straight out at me, it needs to route back around the radio.
I ordered an angled plug, hopefully that will take care of it
