NX-720
webatch
Does anyone have a pin out for the rear connector on the NX-720?
We just got a batch of NX-720's w/ the GPS antenna. We have them programmed so that pushing a key will cause the lat/long to display on receiver. Good information for the Medivac Helo. I wanted to set up an AVL system but the dealer told us it wasnt a good idea because the AVL would take priority and over-ride voice communications. Seems odd!
tneal901
Not true.. The AVL data will not override the audio in fact in digital format, the avl data can be sent on PTT key. I have systems running AVL and the latest system is using the 720 without any problems ans I have the lat/long display setup to come up on key press as well. PM me if you need more info.
webatch
Thanks for the reply. We are just getting the radios installed. Its taking me a bit to install 70 radios... I've never set up an AVL system before so that will be new experience. The county uses WTH Thinkmap software so thats probably what I will have to use for software.
Do the units in your system only show location when they are using / talking on radio?
