Hello Gentlemen,
I'm using KPG-141DN and trying to program some truck radios for our local water utility. I am very wet behind the ears on this products, but I'm trying to learn.
We have NXDN conventional channels setup in 3 zones on the radio, with a 4th zone used to monitor NOAA weather radio frequencies. I would like to set a zone up to monitor fire department frequencies as well, but was wondering if there was a way to make a zone that automatically turns on scanning only with the radio set to that zone. So, you can select zones and channels in zones 1-4, but setting the radio to zone 5 automatically scans all frequencies in zone 5.
I also noticed that the zone ID persistently shows, even when changing channels within a zone. Is there a way to change this as well within KPG-141DN so that channel ID displays instead of the zone?
Thanks!
Thanks!
