NX5000 PTT tone
N2PDQ
Was wondering if there was a way to change the PTT keyup tone. I see where you can change the alert tones, but not sure if one of those is assigned to the PTT.
kd4efm
Florida
No, just those and power up are adjustable. You can change the pitch, but not the triple chirp tone.
N2PDQ
Thank you, thats what I thought. You mentioned you can change the pitch? Didn't see that option, where is that done?
Giddyuptd
Here and there
The ptt proceed tone is a check box in optional features 2 under conventional. You can do a release tone or a ptt proceed tone which is what I use.
If you use any emergency alarm rx features I have setup mine to be similar to Motorola. Pretty close to the tones and sequence used. I know that can be changed with tones.
