NX5000 Series Mixed Mode?
03msc
RF is RF
EM45
Local agency is currently running in mixed mode analog and NXDN. I have them programmed in a channel (rx only...) but in analog mode since previously they were only analog. Is there an easy way to switch that to mixed mode analog/NXDN? Or do I have to create a new personality? Or what is the best way to get it programmed to rx them in either analog or NXDN?
tweiss3
Is it time for Coffee?
Ohio
The personality the channel/zone is in has to be NXDN, but you should just be able to switch it to dual mode in the software.
03msc
RF is RF
EM45
I'm in personality mode so my zones are all a mix of analog/dmr/nxdn already. Just curious if there is a way to easily convert this currently analog personality to mixed analog/NXDN.
kd4efm
Florida
Go to said channel, if you did it under nxdn personality, you can select what transmit you want on first key up.
Mixed mode will receive what it hears first and transmit that mode unless the auto reset timer expired, then it does what is programmed for TX mode.
03msc
RF is RF
EM45
It was programmed as analog but this tells me what I need to know. Sounds like I need to do one as NXDN and then set to mixed to rx both NXDN and analog.
