So, as a long-time participant on the threads, I know that some of these questions are probably already answered in an existing thread or somewhere in a reply on another thread but I ran across a deal from a fellow ham who was wanting to sell his dual-deck setup with the 20R and for the price he quoted me I couldn't pass it up. Anyway, with that in mind I have some questions for those with this type setup...sorry if they've been answered before.
I may think of something else and ask it in a reply later. Thanks in advance!
- Volume - I know the programming can specify whether all decks are at the same volume or the unselected deck(s) are at a lower volume...my question is, can this be setup as a menu option or programmed to a button for quick change? In other words, if during general scanning I wanted all at the same volume but then during a net or a QSO I decided I wanted the other deck(s) quieter, can I change that in a menu setting or only in programming from D1N?
- Mic Buttons - Using a DTMF mic, I currently on my singled deck have some of the mic buttons programmed where they will adjust the volume or turn scan on/off, change zones, etc. I am assuming that on a multi-deck setup, the buttons will function (or can function) differently depending on which deck is selected at the time...correct?
- Lastly, for those with this setup...what 'advice' do you give to someone who is going to be setting it up for the first time? Meaning, what do you wish you'd know at first that you kind of had to figure out and tweak your settings to get it how you want? I'm more talking about programming intricacies or settings it took you a bit to get 'right'. The dual deck, single head config is already done on these as far as dip switches and the like.
