Nx5200 scan add/delete question
nick223
Ottawa Illinois
Once I take a channel out by the scan add/delete button does the channel get added back in if I turn scan off and back on?
I know it stays out of the scan “bank” if I power cycle the radio. Until I manually add channel back in
just trying to get clarification since I don’t have a nx5200 at the house right now.
thanks.
KK6ZTE
California
If scan is on, it will kick it out of the list until the radio is power cycled or scan is toggled on and off, so it's a nusiance delete.
buddrousa is only correct if you add/delete while NOT scanning--then you are modifying your scan list.
wx5uif
Broken Arrow, OK
I have a button set up for Scan Delete / add. Once I turn the radio off / on the channel I deleted is back to scanning.
78218
KK6ZTE
California
Ah, you edited your post to remove the incorrect info. You're quick
KK6ZTE
California
Scan normal is a mode that disables "Priority Scan" which checks one or two important "priority" channels for activity.
You can use Scan On/Off to toggle Scan using Priority or Scan Normal to toggle scan and ignore the priority settings.
