NX5300 stack
Middle of Nowhere, Tn
I have a NX5300 with the DMR option and I have it programmed for several amateur DMR repeaters in my area. My question is two parts 1) is there anyway to have the radio not hold on the last received ID in the display and return to the normal display? 2) is there anyway to turn off the blinking little note in the display? I have unchecked every box I can find.
kd4efm
Florida
ID hold, there is a timer for that.
Music note, no, that is part of the received calls function. I do think it can be, but it has never bothered me,
in fact my wayward mind, I actually like it because I am always doing something and the volume is turned down and I might miss a call.
then again, I am also on a nxdn trunk system so I get call alerted at times.
kd4efm
Florida
I'm working on a code plug now, i will let you know in a few
Sent from my SM-G935P using Tapatalk
kd4efm
Florida
go to NXDN / NXDN INFORMATION / General Section
*clear caller id stack on reply (check) if you have not tried this one.
on auto reset, what do you have checked and not checked?
Same should be true under P25, DMR sections as well.
There you can exclude the unit id display on group call.
Let me know your findings.
I don't have an issue with NXDN and I don't have P25, my problem is with DMR.
Under my DMR/DMR Information/General> Unit ID display on group call is checked, Clear caller ID stack on reply is grayed out, both boxes in the stack box are unchecked, caller ID drop down is set to none. Signaling reset, Voice auto reset, and message auto reset are all set to 3 seconds.
