NX5700 KES-5 Connection
nozzle75
Easley, SC USA
I have a multi-band (VHF and UHF) using the KCH-20 control head. I'm trying to use external speakers with the six pin connector on the rear of each RF deck, but I'm having trouble getting RX audio. Can anybody verify which pins I"m supposed to use on this connector? The manual says use pins 5 and 6 when using KES-5, but I do not get audio using those pins.
kd4efm
Florida
Did you check the setting in the software by chance? I'm out camping so I'm not able to pull up the guide.
kd4efm Evans, sent using TapTALK on my HTC M9
jrw14493
The NX-5000 series decks don't have a 6 pin connector on the back. There is a 3.5mm jack for audio. You can also get it out of the back of the KCH-20 with an adapter cable.
The TK-7150's had a 6-pin molex connector on the back.
nozzle75
Easley, SC USA
Thanks all. The 5000 series does in fact have the ability for the six pin molex connector, but when ordered with it, the radio ships with a relay board installed that has two jumpers. One of the jumpers directs the audio to either internal or external and it ships with the jumper set for internal. Once I swapped it to external, I was able to use pins 4 and 5 on the molex connector.
