I am currently in the process of making a 3.5mm to RJ45 key loading cable. The photo below is a patch cable I cut the end off and followed the KFD tool GitHub for this pinout:
The problem is the radio does not enter keyload mode in the cable’s current state. Any ideas? I’m pretty sure it should just enter keyload mode with this plugged in on power up. I do believe the diode is oriented correctly also. Pin 4 (no diode) is eventually going to be ground and pin 2 (with diode) is data.
- 8P8C Pin 1 - Hirose Pin 4
- 8P8C Pin 2 - Hirose Pin 2
- 8P8C Pin 5 - (Cathode) Schottky Diode (Anode) - Hirose Pin 2
- 8P8C Pin 6 - Hirose Pin 4
