NX96 CC in Gatineau (Hull)
roots
QC, Canada
Hi Guys,
I found a NX96 Control Channel on 165.5400, as per IC it is owned by EXELRADIO. It's currently setup with 4 channel (1 for control channel & 3 voice).
I'm looking for the voice channel right now if by any chance some of you got anything in this range, I will continue my search.
Thanks,
r0ot5
mmisk
Ottawa Canada
Hello Roots
DSD+ shows this as system 2076 Site 1
I also see system 2076 on 164.235, and 162.120 both show as site 2
Mike
DaveH
Ottawa, Ont.
When in doubt I go to TAFL and look up the frequencies associated with the CC at a site.
Try 153.275, 164.235 and 164.400. Mixed analog/digital system apparently with school buses.
Dave
roots
QC, Canada
Thx guys, didn't thing about searching for associated frequencies at a site.
will continue my search and I will map the system and submit it.
DaveH
Ottawa, Ont.
When you search the frequency, note callsign (in this case CIK432) then do a Callsign
search. You sometimes see a bunch of frequencies. In this case not all are part of the
system, they have other conventional repeaters. It sure narrows down the search.
Dave
roots
QC, Canada
System is also in Mix Mode so control channel frequencie is used by voice when all other channels are busy, I did happend this morning, they only seems to be using 3 channels for voice only now.
DaveH
Ottawa, Ont.
Are you certain that this happened, or possibly intermod wiped out the CC for a short time?
(I've had this occur). Not sure of the finer details of systems like this, but it seems having
the CC disappear when trunked calls are in progress would be bad, unless the system
is set up to handle this.
Dave
roots
QC, Canada
I spoke with a tech and he confirmed that NXDN can be setup this way, not always the best because when it happen, all other channels cannot be use to transmit voice.
Sent from my SGH-I337M using Tapatalk
