Anyone have any experience on how long it takes the R30 to decode an encrypted signal? Tenth of a second? One second?
And no lectures about encryption please.
I have never noticed a delay. It passed unencrypted signals, and switches between encrypted and unencrypted seamlessly.
If you are scanning a TRS, you will have to put the channel in as clear and then again with the encryption key. If you have more than one key, the channel is duplicated for each key. I have not noticed any appreciable delay in doing this and it happily will skip over the channels if they are assigned the wrong key or if encrypted with out the key.
In other words, if the channel is mixed, it will not automatically select the encryption if the channel is set to clear, conversely it seems to remain muted if a clear transmission occurs when you have the channel set to enc with a key.
It will decode an encrypted NXDN signal with the right key set almost instantly, very little difference if any when compared side by side with a Nexedge transceiver.
With no key set, an R30 will lock onto an encrypted channel but it mutes the audio output. With the wrong key set, an R30 will unmute and output garbled audio. It doesn't have any KeyID capability, and it ignores those bits of the transmission, so if two different keys are used on the same channel, it will come through clear on one (when the right key is used) and the other as garbled (wrong key used).
>so 1-32,767 are the key ID’s.
Not quite right. NXDN has nearly 33k possible keys from 1-32767. Most portables can have 16 possible keys programed at any one time so that's 16 possible KeyIDs (KeyID 0-15).
The manual says the R30 has a feature called Fast Unmute, which AFAIK claims it will only unmute the audio when the key matches that in use. It's been a while since I tested but my recollection was it did nothing/didn't work as advertised. I reported it to Icom and haven't heard/seen anything from them since.
Are you confusing DMR with dPMR? An Icom R30 won't do anything with DMR, scrambled or not.Ill have to check my firmware version, but I remember when I did this like a year ago, it remained muted on both DMR and NXDN with incorrect keys.
