I received a new 436 today and after updating the firmware I purchased the NXDN key. How do I enter the key into the 436 and then how do I verify that it's there?
Thanks...
On the scanner:
Press
Menu (the bottom button on the left side)
On the Menu opening screen, scroll down to Settings (the last item), and with
Settings highlighted, press the
E (yes/enter) key
On the Settings menu, scroll down to
Upgrade & select it by pressing
E again.
On the Upgrade menu, choose which upgrade you are doing, and with it highlighted (selected) press
E aian.
Enter the key using the scanner's keypad. Enter all characters- letters, numbers, as well as the '-' (dashes) between the groups of letters/numbers of the key.
DO NOT press
E until you have entered the complete key. If you press
E before all of the key is entered, you'll get an error warning for 'invalid key.
Be sure and look at the key closely; the way the characters are grouped can fool you into making a typo.
Once you have correctly entered the key, and pressed enter, you'll see a brief pause as it is being applied.
To verify that the key was entered & the feature activated, go back to the
Settings menu & choose
Upgrade again.
When you try to go back to enter a key, you'll get a message that it has already been applied.
