Anyone else tried this?
I have noticed over the past several days that I was missing a lot of NXDN comms on my 536. I tried creating departments with both the ARC536 and Proscan with the same result. Some talkgroups seems to work fine some do not.
So I did the following to try and do some troubleshooting.
I took an active talkgroup that was programmed via software but I was not hearing anything on when I know there was traffic present. So I manually entered the talkgroup ID into the scanner via the scanner keypad and ammazing enough, worked perfectly and decoded traffic every time the channel was active. Great! Programmed again with software and scanner totally skips the active talkgroup.
Has anyone else tried this and got similar results? I am wondering if the software is missing something when its downloading into the scanner.
I did try the new V17 firmware as a final test before posting this. Got the same results with V17.
