I have been playing round with DSDPlus (fast lane) and really like it. The only issue I am having is that I cannot hear any NXDN voice calls while honed in on the control frequency. It appears to be trunk tracking. If I manually tune to a non-control channel, it decodes but only one side of the conversation as expected. Interestingly, it appears everything is being detected and decoded, but I get no decoded audio through my speakers. I tested the same setup with my SDS100 and have had no issues. Everything is clear. I used the same antenna and coax when testing the two. Keep in mind, I have had no issues with P25, DMR, or Con+.
In my DSDPlus.frequencies file, I added the following: NEXEDGE96, 107, 1, 0, 452.3875, 0.0, 0
Everything in DSDPlus.exe is set to default including the Input, Output, Decoder, and Control drop downs. The system in question can be found here: J and K Communications Diga Talk Trunking System, Various, Indiana. What obvious key configuration am I missing?
Thanks!
Thanks!
