NXDN TRS setup help?
OHIOSCAN
Lorain Cnty, OH
Been trying to get a local NXDN TRS setup but cannot get the voice following to work. The first 2 .bat
files launch and start following the system but the last 2 .bat voice following files are not working. My P25
TRS files run fine but I am missing something on the NXDN setup.
Any ideas?
(1) FMP24.BAT
FMP24 -i1 -o20001 -_1 -b4 -wsl15.920 -f424.5625
(2) CC.BAT
DSDPlus -rc -i20001 -_1 -wsl940.1070 -wss100.200 -wel500.15 -wes425.900 -weh18 -wcl500.950 -wch21
(3) FMP24-VC.BAT
FMP24 -i2 -P71.0 -o20002 -rv -wsl245.920
(4) VC.BAT
DSDPlus -O NUL -rv -Pwav -i20002 -_1 -wsl940.1310 -wss100.200 -wel15.15 -wes425.900 -weh18 -wcl975.15
(FREQEUNCIES File)
NEXEDGE96, 197, 1, 1, 422.3375, 422.3375, 0
NEXEDGE96, 197, 1, 1, 422.6125, 422.6125, 0
NEXEDGE96, 197, 1, 1, 424.5625, 424.5625, 0
NEXEDGE96, 197, 1, 1, 424.7125, 424.7125, 0
NEXEDGE96, 197, 1, 1, 424.7625, 424.7625, 0
NEXEDGE96, 197, 1, 1, 424.9375, 424.9375, 0
NEXEDGE96, 197, 1, 1, 424.9625, 424.9625, 0
slicerwizard
Toronto, Ontario
You have all of the frequencies set as channel 1? They can't all be channel 1.
The channel numbers have to match the channel numbers that show up in the CC channel display.
OHIOSCAN
Lorain Cnty, OH
NEXEDGE96, 197, 1, 4, 422.3375, 422.3375, 0
NEXEDGE96, 197, 1, 26, 422.6125, 422.6125, 0
NEXEDGE96, 197, 1, 182 , 424.5625, 424.5625, 0
Ok these are the Ch # I have so this is how it should be?
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Ohioscan,
I thought the system was 191? Is it actually broadcasting L197 and not L191 ? If it is 197, then I need to make a change in the DB because I have it in there wrong. If it is 191, then you need to make a change.
DSDPlus.Networks
NEXEDGE96, 191, "Electrocomm UHF NEOH (NXDN)"
DSDPlus.Sites
NEXEDGE96, 191, 1, "Parma"
NEXEDGE96, 191, 2, "Akron"
DSDPlus.Frequencies
NEXEDGE96,191,1,4,422.3375,427.3375,4
NEXEDGE96,191,1,26,422.6125,427.6125,26
NEXEDGE96,191,1,182,424.5625,429.5625,182
NEXEDGE96,191,2,216,424.9875,429.9875,216
Of course, in the frequencies file I think the last number does not matter, so it looks like you are correct.
The only thing to check is to make sure it is truly Network ID 197 (as you have suggested) or Network ID 191 (as I have suggested). And if I'm wrong and it truly is network 197, please let me know so that I can fix the DB.
Mike
OHIOSCAN
Lorain Cnty, OH
Ohioscan,
No just a typo it is Site 191
Mike
