UPDATE: It has started working again. All I did was close and then restart DSD-VC. I wonder if switching from DMR to NXDN caused and issue?
I'll be keeping and eye on this to see if that's it or if I did something else to correct the issue.
I'm trying to monitor a UHF NXDN trunk system. I've monitored before and can monitor the sites that use composite channels.
The control channel follows the voice channels accurately, FMP24 generates the correct frequency, and I even get a voice alert "beep" when a voice channel becomes active. I can see the TG and Unit information in the Voice Channel Console. Signal strength seems fine.
Just no audio.
I have the BW set to 4, Group Voice Calls set to Normal, speakers are on. Monitoring Threshold is set to default. Output is set to synthesize all digital audio.
I have no problem listening to DMR and MotoTrbo.
I've tried other BW settings, but that reverts to 4 every time there is signal on that VC.
I'm sure I've changed some setting inadvertently, but I can't see what it might be.
Anyone have any ideas?
Just no audio.
