NXDN trunking with DSD Plus Fast lane..
slicerwizard
Toronto, Ontario
You add data for each site that you plan to monitor to the DSDPlus.frequencies file.
Click on the site names on that page to get the channel numbers.
Add the channel entries like so: NEXEDGE48, 68, 4, 812, 461.875, 466.875, 0
kd5dga
Killeen,Texas
I appreciate the help on this. Merry Christmas.
kd5dga
Killeen,Texas
Please help, I still dont understand what I have to input. Does anyone have an example frequency file I can look at?
Thanks,
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Thanks,
Before you have somebody write up samples, why not tell us exactly which site(s) on that system you are trying to monitor? That way we can give you precisely what you need and not just a sample.
mike
cg
Connecticut
I always try to go in order. Set up Network, Sites, and Frequencies. I usually let it run before entering TG aliases.
Open the DSDPlus.NETWORKS file (as a text file) and follow the line format at the top of the page. Then Site, etc. You then might have specific questions which are much easier to answer than very general ones.
chris
kd5dga
Killeen,Texas
cg
Connecticut
Try this:
Add to Networks:
NEXEDGE48, 68, "Bearcom"
Add to Sites:
NEXEDGE48, 68, 10, "Belton"
Add to Frequencies:
NEXEDGE48, 68, 10, 832, 451.87500, 0.0, 1
NEXEDGE48, 68, 10, 984, 451.21875, 0.0, 2
NEXEDGE48, 68, 10, 986, 453.01875, 0.0, 3
chris
kd5dga
Killeen,Texas
Thanks for the reply and also I see now that how this is all set up. I assume that every line I paste that I should use a ; prior to the line information? for example'
cg
Connecticut
NO
That is reserved for comments and is ignored. That's why all the text lined and sample freqs are done that way, so they are ignored.
chris
kd5dga
Killeen,Texas
Ok cool and thanks. This is a learning curve like I had with understanding Linux a few years ago. Its a bit overwhelming at first.
