NXDN voice question
bobruzzo
W1AV
Cranston, Rhode Island
I have been monitoring a local NXDN business system. The frequency is 451.9125. On the DSD plus screen, the black screen it shows NXDN48. When a call comes in, the audio is nice and clear but it has a little bit of that "motorboat" sound coming in along with the voice. Is that normal or do I need to adjust something?
lwvmobile
EDACS-FM
Lafayette County, FL
Yeah, some NXDN48 channels have that burst that occurs every 60 seconds or so. Its kind of annoying to listen to, but its nice if your in exploration mode, that way you at least know there is an NXDN channel there. Not all NXDN have it though. You might be able to disable it if you disable monitoring 'source audio' in the input menu drop down. Not sure if that's a digital motorboat or an analog one.
bobruzzo
W1AV
I am new to sdr so I will experiment. The only NXDN around here is a couple of uhf (400mhz, 935 mhz) business/ambulance companies. I just wanted to try to listen to them. But probably not worth spending the $75 for radio upgrade. DMR is scarce though and I havent been able to decode anything except control channel data. Not sure where DMR voice is.
slicerwizard
Toronto, Ontario
You have Source Audio Monitoring enabled.
