i was wondering if their is a way to receive nxdn i am using a radioshack pro 106
were could i buy a discriminator tap
Kenwood will happily sell you an NXDN radio, as will Icom, who also uses the NXDN protocol.
You will need to know what frequencies you need access to:
VHF and UHF are available from both manufacturers.
Kenwood also makes 800MHz radios and 900MHz radios. No 700MHz.
You will need to know if they are using 12.5KHz NXDN, in which case you would need Kenwood, as Icom only supports the 6.25. If they are using 6.25, then you could use either.
You will also need the programming software.
I've got a few hundred Kenwood NX-410's and NX-900's at work. Good radios, and you'd be able to get those in the $700 range, a bit cheaper if you wanted VHF or UHF.
Programming software for the Kenwood radios (KG-111) is really easy to use and nicely set up. Figure another $100 or so for software and cable.
By the time you get accessories, radio, extra battery, software and cable, figure you'll be out around $1000.00.
These radios can be programmed for receive only, so you'd be OK there.
VHF and UHF models of the Kenwoods will do the respective amateur bands. They will do both wide and narrow FM, also.
I have no personal experience with the Icom's.
Oh, and if it's trunking, then you have some more issues:
Kenwood and Icom trunking are not the same and are not interchangeable.
From my recollection, if the system you want to listen to is running trunking, then you are pretty much out of luck without the system key. I don't think you can monitor a single repeater or group of repeaters and be able to listen in on a trunked system like you can with analog..
You either have to have the system key, or you are out of luck.
No agency should be handing out their system key, so very unlikely you are going to get it unless you have a really good reason.
From my recollection, if the system you want to listen to is running trunking, then you are pretty much out of luck without the system key. I don't think you can monitor a single repeater or group of repeaters and be able to listen in on a trunked system like you can with analog. You either have to have the system key, or you are out of luck.
I'm told at my job only the director of security has that and they change it every week.
That is my understanding to. But with "Trunking capable" scanners - why worry about listening into one repeater.
Again. No need to worry about the key, when you have trunking capable scanners.
GRE PSR500 Handheld Digital APCO-25 Triple-Trunking Scanner : Handheld Scanners | RadioShack.com
RadioShack PRO-163 1000-Channel Triple Trunking Scanner : Trunking Scanners | RadioShack.com
Trunking & Digital - " In general" = Digital Scanners & Police Scanners: Radios | RadioShack.com
online = Trunking Scanners
P25 digital & EDACS capabile scanner - BCD996XT, DIGITAL TRUNKING APCO P25 plus ANALOG - UNIDEN BEARCAT MOBILE BASE SCANNER - Scanner World - The Largest Dealer of Scanning Radios in the World
"Home Patrol" Scanner - HOMEPATROL-1, DIGITAL TRUNKING HOMEPATROL-1 PORTABLE UNIDEN SCANNING RADIO RECEIVER - Scanner World - The Largest Dealer of Scanning Radios in the World
So, some radio comms - "Self Described" by the non-knowing...ARE NOT secure.
FF - Medic !!!
