NXDN96 Decoding (DSD+)
Saint
Fort Erie Ontario Canada
I am trying to decode NXDN96 I have 96 % decoding rate but most of the time the audio is garbled and then it clears up and then garbles again, I am using the -fa switch, the audio is not encrypted, any ideas on how to fix it
Sync:-NXDN96 TB DATA
Sync:-NXDN96 TB VOICE e:4r4r7r5m
Sync:-NXDN96 TB VOICE e:34r4r4r
Sync:-NXDN96 TB VOICE e:4m6r
Sync:-NXDN96 TB VOICE e:6r6r6r6m
Sync:-NXDN96 TB VOICE e:5r7r6r3
Sync:-NXDN96 TB VOICE e:2236r
Sync:-NXDN96 TB VOICE e:6r7r6m7r
Sync: no sync
Sync:-NXDN96 TB VOICE e:36r6r7r
Sync:-NXDN96 TB VOICE e:6m7r6r
Sync:-NXDN96 TB VOICE e:134r
Sync:-NXDN96 TB VOICE e:5r6r4m7r
Sync:-NXDN96 TB VOICE e:7r7r7m6r
Sync:-NXDN96 TB VOICE e:6r24r7r
Sync:-NXDN96 TB VOICE e:37r5r7r
Sync:-NXDN96 TB VOICE e:235r
Sync:-NXDN96 TB VOICE e:4r6r34r
Sync:-NXDN96 TB VOICE e:27r1
Sync:-NXDN96 TB VOICE e:2331
Steve
Saint
-fn switch
If 9600 is all You want to decode use this.
-fN Decode only NXDN9600
Good Luck!!
Using the -fn switch and sounds the same, I think it's as good as it's going to get, it's better then nothing at least I can figure out who is on the frequency. I was using DSD+ on a DMR Motorola Connect Plus (TRBO) and it works real good, so I was wondering if I was doing something wrong.
Steve
RonnieUSA
Rowan County,KY (Morehead)
Steve
It's a capitol N, not a lower case n.
The lower case is for NXDN48
-fn for NXDN48
-fN for NXDN96
Saint
Your Welcome.
Lets us know if it makes a difference.
Good Luck!!
I just found the help file and all the information is in there I will read it carefully, the system does not seem to be very busy but I will let know if there is a change.
Steve
