NXR-710 REF oscillator
SAFFA
World
Hi Guys,
I'm looking for a high stability oscillator which I can use on 6x NXR-710 on the same site.
Unlike the NXR-700, you can't daisy chain the oscillators from one repeater to the next.
kd4efm
EL98 Florida
Its really not needed for the x10 repeaters, unless your doing site to multi site data and paranoid.
Sent from my 0PJA2 using Tapatalk
Hi Guys,
There are GPS receivers that will spit out the correct timing signals for these guys. 10MHz, if I recall correctly.
I'm running 5 NXR-900's in a trunked system, 12.5KHz, and am not using the external oscillators. I've heard that with the 6.25KHz "very narrow" NXDN that it's a good idea.
Should be lots of stable 10MHz sources out there. Pretty common item.
New York, NY
You should be able to daisy-chain them using BNC T-connectors on all repeaters. I've done this with NXR-800s and it works fine (allows me to disconnect one repeater without breaking the "chain" and taking repeaters downstream from the oscillator off the air).
Google will help you find a 10MHz gps reference oscillator that will fit your needs.
