NYCOMCO EDACS - Poughkeepsie
Spec
In the South
There appears to be some re-programming taking place as we speak. All City of Poughkeepsie PD vehicles are being re-programmed . Anyone have any ideas ?
Spec
plectron
Ossining, NY 10562
As a matter of fact I was talking to a NYCOMCO guy yesterday about thier trunking system, He said that they are in the process of rebanding their 800mhz EDACS system due to the NEXTEL rebanding. Their UHF LTR system is going to remain the same.
kevin390
Wallkill, NY
I thought rebanding was only going to change Motorola trunk systems and not have any effect on EDACS and LTR systems???? Ray
SCANdal
Silent Key
Hudson Valley, NY
390,
"Rebanding" describes the process of the shifting of users of frequencies in the 800 MHz band (who are currently intermingled) to seperate away two-way systems (moving toward the lower end of the band) from wireless telephone systems (moving toward the upper end of the band), in an effort to prevent wireless telephone systems (namely NexTels) from interfering with two-way radio systems. The changes will effect many two-way systems, regardless of whether or not the systems are conventional or Motorola, EDACS, or EFJohnson LTR trunked; digital or analog; in the clear or encrypted.
SCANdal
paul
Nycomco Edacs
This morning they're "reprogramming" Town of Poughkeepsie police units (Illinois Mountain EDACS system).
APX8000
Sarcastic Member
AES-256 secured
NYCOMCO is also reprogramming Orange County units on the Beacon system...Anyone running Etrunker for the new frequencies/LCN's ?
paul
Nycomco Edacs
There are some new frequencies in the FCC database:
Illinois WPCZ329: 857.0375 and 858.6375 MHz.
Beacon WNVP298: 854.1375 and 859.6125 MHz.
Spec
In the South
EDACS reprogram
This is a two stage re-programming. The first stage is pretty much completed. I would expect to see some effects within the next week or two. Dropped transmissions (fails to follow the trunk etc) would be the first signs. I believe I may have detected some of those already.
Spec
Spec
In the South
EDACS - Poughkeepsie -Illinois Twr
If I am correct the re-banding only effects 860 up. If this is true then there would be a need to replace 3 frequencies in the present LCN for Illinois Twr. I tend to doubt that they would drop a frequency and lessen their channel load capabilities. So if the two frequencies listed are indeed replacements then there still is a missing frequency. Anyone running e-trunker ????
Spec
paul
Nycomco Edacs
The changes to Illinois Mtn. started yesterday. This LCN is tracking -so far- on a PRO-94:
1: 854.4125
2-4: blank
5: 860.7125
6-8: blank
9: 857.0375 (new freq.)
10: 858.6375 (new freq.)
11: 855.3125
12: 859.8875
13: 855.9625
14: 859.7875
15: 860.8875
16: 856.1125
17: 858.0375 (new freq.)
18: 858.1125
19: 859.1125
20: 860.1125
Spec
In the South
EDACS- Almost I think
I think there still is a missing freq. on the Illinois twr. I've tried your list Paul and it IS working however there still seems to be some missed transmissions. I have it going in both a 396 and a 780. Both are behaving the same way. I'll give it a few days and see what happens.
Spec
paul
Nycomco Edacs
Same here. That's why I put "so far" in the post! Please post whatever you get so this can be finalized.
I also have a "so far" LCN for Mt. Beacon:
1-2: blank
3: 857.7125
4: 854.1375 (new freq.)
5: 856.6875 (new freq.)
6: 859.6125 (new freq.)
7-10: blank
11: 856.1875
12: 857.1875
13: 858.1875
14: 859.1875
15: 860.1875
pro92b
Mutated Member
Two sites still have blank LCN's and may undergo further changes. The correct line-up as of this posting is below.
Code:
 1 854.4125
 4 860.1125
 5 860.7125
 6 859.1125
 7 858.1125
 8 856.1125
 9 857.0375
10 858.6375
11 855.3125
12 859.8875
13 855.9625
14 859.7875
15 860.8875
17 858.0375
Beacon WNVP298: 854.1375 856.6875 and 859.6125 MHz.
 3 857.7125
 4 854.1375
 5 856.6875
 6 859.6125
 7 858.1875
 8 859.1875
 9 860.1875
11 856.1875
12 857.1875
Kingston: WNPS671: 859.3875 MHz.
1 855.4875
2 858.7375
3 858.9875
4 859.7375
5 859.3875
6 856.1375
7 857.1375
Ellenville: WNMD318: 854.4625 MHz.
1 854.4625
2 858.8375
3 856.5625
4 857.5625
5 859.5625
6 860.5625
APX8000
Sarcastic Member
AES-256 secured
Pro92...are you running etrunk or is that from plugging and playing ?
Anyone have Arden and Graham fingured out yet ???
pro92b
Mutated Member
Channel numbering was determined with the help of Etrunk. Other methods are way too tedious and produce wrong results half the time.
Note that 859.1875 is off line on Beacon at the moment. Things may not be going smoothly for NYCOMCO.
Graham and Arden are not receivable here. Most of their frequencies are above 866 and will shift down by 15 MHz to the 851-854 range. That's why the other four sites vacated 851-854. I have not seen any new license listings for Orange county or NYCOMCO in the 851-854 range. NEXTEL does hold licenses for many of those frequencies and they have to move before Graham and Arden can be rebanded.
