NYS Trooper Freqs for Buff/Erie Co.
nycirnwrkr
Woodstock,NY
NYS Trooper freqs
I thought it was very quiet on interstate 87 and 84 intersect. I get a lot of Thruway authority.
jf222
Silver Creek, NY
NYSP do not have primary coverage in Buffalo/Erie county - nor in most of WNY - they are usually heard on the county sheriff's frequency as they work with those departments. You may hear some infrequent dispatches if you are near the base being used or some car-to-car transmissions. [remember base-to-car and car-to-base are on different frequencies.
Some counties use the licence plate number of the car [eg 3A27] - Chautauqua county uses the last three numbers of the radio number from the rear quarter panel [x723] apparenty because this is the GPS number that shows on their computer map display.
Spec
In the South
NYSP- Where did they go...
Voice traffic diminished when the MDT's went in service. Cars can e-mail / IM each other and the dispatches are sent via MDT.
Spec
chewie327
Latham NY
I-87 is the Thruway and I-84 From the CT line to the PA line is patrolled by the Thruway troop also. 453.425 or 453.525 are simulcast so listen to whichever gives you a better signal.
MS1170
453.525 is simulcast? what is the one they are actually using? throughway authority that is.
cookiend15
Banned
Give these frequencies a try. They are for the Erie County Sheriff which you might hear the NYSP on.
155.370
453.5125
460.450
465.450
460.200
465.200
460.400
465.400
I hope that this helps
Chris
Lorna68fs
Buffalo, New York
I live in northern Erie County and I hear a lot of activity on NYS police frequencies. WNY is Troop A. I hear a lot of dispatches on 155.505 and the mobiles on 155.535. Where I live, mobiles use a tone of 110.9 Hz. The base uses a few different tones, while the Clarence base doesn't use any, so it's best not to program a tone for the base, that way you won't miss anything. I also hear activity on 154.665 (110.9) car to car, 154.695 (CSQ) statewide emergency, and 155.565 (110.9) BCI. Anyone who lives near the 290 in Amherst can hear the Radar speed blitz' they do on weekday afternoons, on the car to car freq. The Thruway State Police in WNY use 453.525 and 453.425, both with a tone of 123.0
sid2727
155.370
453.5125
460.450
Thanks. Those 3 are new to me so I will give them a try. I have already programmed every other freq. listed on this page but I can't pick most of them up. I'm sure I need a better antenna system.
vonivo
i have these freq's programed into my radio but i neaver hear anything....am i missing something?
Lorna68fs
Buffalo, New York
What location are you listening from? I live in Clarence (NE Erie County.) In other counties, like Orleans and Genesee, the State Police transmit on those counties trunked systems. It may also depend on what antenna you're using. The State Police don't use repeater's here, except the Thruway. I use a Ferret multi-band antenna on a 40 foot pole with 9913 cable. If you're using a rubber duck or the back of set antenna's that come with the scanner, you're not going to heard the mobile's very far away. The base should come in okay though. Anyway, it doesn't matter much anymore. If NYS is successful with their Open Sky system, even the stuff I hear will go silent in about 6 months.
jf222
Silver Creek, NY
Don't worry about silence - neither Buffalo nor Erie County have the money for new radios = Erie County fire is NOT going on the new system = Chaurauqua Fire may move the dispatch, but paging must remain as is & individual departments will at most get one protable to contact dispatch [individual companies each have own licence for base and all the current frequencies]
Remember, unless Feds give grants for non P25 systems, no one has the money for radios. Each FD would need base, vehicle radios for at least 8 vehicles, plus at least 8 portables [8 x $3500, 8 x $4500, plus base]
