Object Id in arc500
fireman3214
Everett, PA
When I set up a conventional scan list in arc 500, all of my the channels have 0 in the object Id column except for 2 channels which the column is blank, is it ok for that column to be blank or is there something wrong
jaspence
Michigan
Object ID
If they scan properly, I wouldn't worry too much. Mine are numbered 0 through 566, and the number is one more than the number position of the frequency on the left side list. ID 0 is the first memory position, ID 1 is the second channel in the list, and ID 566 is frequency 565.
